View Poll Results: have you had an engine problem
yes, major blow up
14.55%
yes, minor fault easily rectified
12.73%
no, its run like clockwork
72.73%
Voters: 55. You may not vote on this poll
Old 06-02-2004, 01:53 AM
rahula's Avatar
no problem after driving the car hard 90% of the time and doing 22k miles in 12 months on an 02. Will let you know what the 04 is like.
Old 06-02-2004, 02:09 AM
Vixen's Avatar
Originally posted by GSi
Sounds like you have a bit of a problem child there Carrie
EDIT: Does it take after James
The sluggy engine was after we put normal unleaded in - so that one's sorted, the stalling is a bit annoying. Need to take it to another garage for second opinion. Not overly impressed with Slough.
Old 06-02-2004, 02:52 AM
Nick Graves's Avatar
Lower,
Perhaps your title needs tightening a bit:
Apart from the MAP sensor, the other problem I have is it's only 237BHP!
That's hardly a catastrophic failure, but a full JDM 250 would be useful.
Old 06-02-2004, 02:56 AM
GSi
GSi's Avatar
Mine runs fine when I have to put 95 unleaded in... I can honestly say I can't tell the difference..
Old 06-02-2004, 03:06 AM
A slightly sharper throttle response is all I could say is the difference. I'm not sure one could measure a performance difference.
It feels better on 98, but then it never has any long enough on 95 to remap. I only ever put a splash in in an emergency.
Tell you what though, 100 makes it a fcuking road rocket!
Old 06-02-2004, 04:12 AM
supers2k's Avatar
Never had any when I had one.
VTEC solenoid went once so it wouldn't VTEC in any gear. 20 mins down Southern Counties later and it was job done. These things are bloody reliable. Started 1st time everytime no matter how cold.
Old 06-02-2004, 04:13 AM
supers2k's Avatar
100 ron. Was that race fuel Nick ?
Old 06-02-2004, 05:21 AM
NeilC's Avatar
I had a re-occuring engine management light, showing as misfires on all cylinders, although car ran OK. No V-tec when light is on
I had a service and new plugs at 60k, still occured
Balmer Lawn Honda said valves needed adjusting, I was sceptical but said ok.
All valves needed adjustment as they get tight with age,
Old 06-02-2004, 06:30 AM
Leggy Blonde's Avatar
I had an entire new engine. I'd call that a major blow up!
This was in the early days and I think was rectified by the oil bolt recall.
Old 06-02-2004, 11:49 AM
davemac2's Avatar
oil filter seals split on a m.m.meet. dont think the under side of the car will ever rust.
(p.s. rescued by ade/jude, and a man restoring his jag in his nearby garage
Quick Reply: have you had an engine problem
