View Poll Results: have you had an engine problem
yes, major blow up
14.55%
yes, minor fault easily rectified
12.73%
no, its run like clockwork
72.73%
Voters: 55. You may not vote on this poll
Old 06-01-2004, 06:39 AM
lower's Avatar
Default have you had an engine problem
the s2000 vtec engine has a repuation for reliability. how many of you out there have actually had a problem?
Old 06-01-2004, 06:45 AM
moff's Avatar
Just the MAF sensor which needed a quick whack with the back of a screwdriver!
Old 06-01-2004, 06:48 AM
Kelk's Avatar
Some dirty Ultimate fuel the other day caused a bit of lurching but nothing else.
Old 06-01-2004, 07:16 AM
Col T Sav's Avatar
Is that one of those highly technical solutions Moff .......
Old 06-01-2004, 07:23 AM
Roadkill's Avatar
Not quite sure about the "run like clockwork" vote. My car has been known to "run like a devil with his ass on fire"!
Old 06-01-2004, 11:22 PM
lower's Avatar
i know that there has been more than one blow up out there. and there must be more people who have had no problems. come on guys, i trying to get an idea of the reliability stats. more votes please!
Old 06-02-2004, 01:11 AM
lower's Avatar
so we now have 104 reads of the post, and only 27 votes. its not that hard!
Old 06-02-2004, 01:19 AM
GSi
GSi's Avatar
You'll get the votes, just be patient
I voted major blow up, but in reality it wasn't a 'blow up' but was a major repair.
I had oil getting into my coolant - not coolant into my oil, which is usually a gasket problem - they cleaned it out initially thinking that I had poured the oil into the coolant by mistake (give me SOME credit Mr Honda!!) then it happened again so they ran some tests and couldn't find any problems at all with pressures etc in the engine.
I then drove about 4000 miles around France with no problem at all.
Then a month or two later it happened again.
Each time it happened, you would never have know unless you checked the coolant. No performance degradation, no over heating etc. If it goes unchecked and you do a long run it eventually forces oil out of the coolant tank as it expands too much and it drips out under the car - which is how I first noticed.
Anyway, they had the car if for 4 days, replaced the engine block (under warranty) - presuming it was a manufacturing imperfection - and ever since then, circa 6k miles, it has been fine.
Old 06-02-2004, 01:36 AM
Vixen's Avatar
Have had the sluggy engine sorted with the Map sensor again. Get the kangarooing which I know is air intake but we had it quite badly, most of this has been cured after we had the 54k service.
Also getting intermittent stalling after going on a long/fast journey and then dropping onto slower roads, rev's drop right down. Honda not found anything and it generally sorts itself out after a couple of days.
Old 06-02-2004, 01:50 AM
GSi
GSi's Avatar
Sounds like you have a bit of a problem child there Carrie
EDIT: Does it take after James
Quick Reply: have you had an engine problem
