Has anyone actually replaced the thermostat themselves?
Whilst at Honda i spoke to one of the tech's who insisted there are 3 bolts for the thermostat housing/to take it out, and you can't get it out from underneath - I've had a quick look and seen the two bolts but i think otherwise. According the service manual there is only 2 bolts.
Has anyone actually replaced it from underneath? i see one bolt is a bit of bugger to get to but an elbow socket with ratchet may do it.
Cheers
Cheers
I can't see space for a 3rd bolt there
Yeah just as i thought and have seen myself. I reckon either a ratchet spanner, elbow ratchet+extension or flexible one should do - but one bolt looks like a tricky bugger.
I'd rather remove the hose and try and use a small ring spanner, those bolts look prone to rounding if you don't get the socket on square.
