Hardtop Bolts
Old 01-13-2012, 09:46 AM
P.J.'s Avatar
Must check it out...
Old 01-14-2012, 08:30 AM
WinFreak's Avatar
Originally Posted by loftust
Your bolts are too short and should be changed ASAP.
You may not be experiencing any problems, but as an Engineer, I'd do something about it rather than increase the risk of the HT flying off.
I think this is a bit overreacted, the standard bolts sit about 5mm through the welded nut in the body panels, so adding the 2mm thick fitting brackets isn't going to cause any problems..
It's not like you only use half the nut depth.
I agree if you are still going to fit it you might as well get a good set of bolts but if it's already fitted I wouldn't bother changing them, its not going anywhere.
And yes I'm in engineering too, if that makes any difference
Old 01-14-2012, 08:51 AM
loftust's Avatar
I'm fairly certain the brackets are > 2mm thick where the bolts pass through.
I'm also risk averse...and in this case, why not
Old 01-14-2012, 08:55 AM
ogg2000's Avatar
The part numbers for the bolts are:
93404-0602008 and 95701-0802008
D
Old 01-14-2012, 08:56 AM
s2konroids's Avatar
I have to agree with winfreak on this point.
I'm from engineering too
Old 01-14-2012, 09:01 AM
loftust's Avatar
Fair do's...what I say isn't gospel by any means.
I've not seen if there is enough excess length on the bolts. If there is, then using them will be fine...I'd just like drive in the knowledge that the HT cannot fly off!
Old 01-14-2012, 09:04 AM
s2konroids's Avatar
I can see where you coming from Matt to be fair. But i dont think its any cause for concern theres enough length in them IMO.
Old 01-14-2012, 09:28 AM
WinFreak's Avatar
I had the oem brackets in my hands today when fitting them to Mardibloke's old S2000 and I think they're 2mm, maybe 3mm thick max.
Anyway there's no need to debate all this, they sell the longer bolts for a reason so if you've got the chance to swap them you might as well I guess, it's not that much work
Old 01-14-2012, 10:58 AM
PedroHicken's Avatar
I will be calling Honda up Monday for these bolts.
Any idea's on prices?
Old 01-14-2012, 11:04 AM
loftust's Avatar
Good for UK prices:
http://www.hondaoriginalparts.com/ho...p?mod_01=23872
This site uses Honda Part numbers, not their own made up ones:
http://www.hondapartsnow.com/Page_Pr...olorLabelID=-1
Quick Reply: Hardtop Bolts
