Hardtop Bolts
Old 01-13-2012, 09:10 AM
PedroHicken's Avatar
Default Hardtop Bolts
I finally have all the gear i need to fit a hardtop to my car bar the bolts to secure the brackets. I know 4 bolts go into each bracket and apprently Honda dont sell them. Any idea which bolts i need?
Thanks guys, appreciated.
Old 01-13-2012, 09:15 AM
P.J.'s Avatar
Are they not already on the car? Mine were when I fitted mine recently...
Old 01-13-2012, 09:18 AM
I havent checked. If they are then fantastic! my brackets hadnt come with anything though and thats why i thought i may have needed them....
Interesting!
Old 01-13-2012, 09:19 AM
loftust's Avatar
P.J. - You are supposed to use longer bolts to accommodate the depth of the brackets!!!
OP - You can download the instructions (Google), which should say what size you need. Failing that, remove one, then buy longer ones.
P.J.'s Avatar
Have a look, when I fitted mine, I took bolts off the car where the brackets go and bolted the brackets in place using those bolts...
EDIT: What do you mean loftust?
Old 01-13-2012, 09:21 AM
Blimey, id check them out PJ..
Old 01-13-2012, 09:25 AM
s2konroids's Avatar
I think used the original too.
Old 01-13-2012, 09:27 AM
loftust's Avatar
Your bolts are too short and should be changed ASAP.
You may not be experiencing any problems, but as an Engineer, I'd do something about it rather than increase the risk of the HT flying off.
Old 01-13-2012, 09:42 AM
P.J.'s Avatar
Really? What length should they be? I will check them out tomorrow.
Old 01-13-2012, 09:44 AM
According to the manual...
4 Bolts, 6 x 18 mm
4 Bolts, 8 x 20 mm
Quick Reply: Hardtop Bolts
