Hard top wind noise at higher speeds
Hi all I've recently bought a hard top for my gt model as the seller sold the top befor the car. I've got it down nice and tight every where no noise what so ever driving at 60-80 but whe I start getting to 100-120 it feels like there's no top on there any advise?
Thanks
Thanks
I also have quite a lot of wind noise. Is yours from the front above the windscreen?
You could try adjusting its fitting by removing the plastic covers and adjusting the 3 (each side) bolts that hold the roof to the brackets, whilst the mounts are all locked, I have managed to get mine a few mm lower by doing this but due to my roll cage not being exactly symmetrical I will never get the roof perfectly flat
Guys lets not get off-topic here I have the same issue and I got rid of the wind noise on the driver side by adjusting the hardtop bolts as mentioned earlier. Just have to do the same for the passenger side next there's a Honda hardtop PDF on the forums that can be searched for to aid you in doing this.
Lot of speed preaching here. Go get a prius.
Mine is noisey from the side, not the top
