Hard top seal
Hard top seal
The seal around the bottom of my hardtop seems to have slipped or is failing. I haven't took the roof off to have a look as I live alone so it's no easy task. Is is a replaceable item or something I will be able to put back on correctly?
I've spent a bit of time searching but couldn't find a similar topic as it kept bringing up soft tops leaking!
Some pics:
Some pics:
When you store the hardtop make sure you store it with the windscreen edge down so to speak. If you stored it the other way up then the weight of the HT is on that seal, a hot air gun and a bit of persuasion should sort it.
JESesq
07-28-2016 11:47 AM
6262
06-11-2014 06:18 PM
