Had my Geo done today
Old 11-06-2010 | 07:45 AM
Madfish's Avatar
Default Had my Geo done today
What a difference!!
Had it set up to Honda spec at local 4 wheel laser allignment place. Every single adjustment was out of spec, some by quite a bit. The rear wheels were both pointing slightly to the left!
After all the adjustments were made everything is now back in spec and she drives SOOOOO much better. Much more stable, lots more grip even rides the bumps better. It also got rid of the crashing noise I had from the rear suspension over short sharp bumps!
I'll post a pic of the readout when I get chance but it basically went from all reds to nearly all greens :-)
It's just the rear camber that is slightly out of spec but by a very small amount, i'll let the experts on here advise if it's going to be detremental in any way but the garage says it is fine :-)
The really good news though was that the underside of the car was really clean with very little corrosion and all the bushes were free and in good condition :-)
I'm a happy man and already used nearly a full tank of petrol enjoying the new set up today ;-)
Mark
Old 11-06-2010 | 07:53 AM
DOJOD's Avatar
Great !
sounds like money well spent.
I had a day off yesterday and removed and copper-slipped all my suspension bolts
They all came out OK. (50k miles MY2002).
Next job is having it set up but I'm not sure where to go in West Yorkshire (Wakefield)
Dave
Old 11-06-2010 | 11:58 AM
Madfish's Avatar
Here's the printout. Sorry it was a bad print which was then photo'd with my phone...
Thanks,
Mark
Old 11-07-2010 | 10:49 AM
Riverside Red's Avatar
Sorry to be cheeky but what did it cost? Need my geo checking, and last time I had it done was at CoG which is a hell of a drive from Billog.
The S has really tunable suspension settings and I have most of settings set to one end (on Chris's from CoG recommendation) which gives more grip at the rear and more settled braking and cornering on bumpy surfaces.
RR
Old 11-07-2010 | 11:00 AM
Si2k's Avatar
You need some more rear camber
Old 11-07-2010 | 01:09 PM
Madfish's Avatar
It cost me £70 which I think is very reasonable... I will get the geo done again soon once I have fitted my coilovers and specify more rear camber. What is the benefit of more rear camber?
Old 11-07-2010 | 01:13 PM
MB's Avatar
MB
Member
Agree with Si, bit more rear -ve camber and the values a bit closer too
Old 11-07-2010 | 01:39 PM
m1bjr's Avatar
Run out checks not performed.
I would request a refund.
tsk tsk...
Old 11-07-2010 | 01:56 PM
Madfish's Avatar
Oh well, looks like I've not got such a good deal. On a positive note it has improved the feel of the car dramatically and I have to get it done again once the new suspension is fitted. Next time ill take it to one of the more trusted geo places and get it done properly...
Old 11-07-2010 | 02:08 PM
Si2k's Avatar
It looks pretty decent to be fair, but the rear camber is out of the OEM spec.
Quick Reply: Had my Geo done today
