Grade of Engine Oil for UK Drivers
Old 05-15-2014, 10:55 AM
  #61
ben5560's Avatar
Well i was only going by the manual, since only just getting the car i'd rather top it up with what i know it should have...not with what i think will do and mix it with whatever is already in there...
Old 05-15-2014, 01:09 PM
  #62
mikey_w50's Avatar
Castrol are the oil experts and recommend Edge 5W-40.
Also to confuse this more you can get edge 5W-40 in A3/B4, C3 or VW 505 01 spec. All are fine for the S2000 but technically the VW spec has a higher lubricity.
Old 05-15-2014, 01:13 PM
  #63
richmc's Avatar
Originally Posted by Dembo
Originally Posted by ben5560' timestamp='1400151140' post='23160876
So why are we using the 5w-40 when the manual clearly states 10w-30?
People think a higher number is better.
People also think it helps protect the TCT from premiture wear.
Old 05-15-2014, 02:17 PM
  #64
N777CK T's Avatar
Well I got my oil and video'd my oil change, you can see it here if it helps anyone
http://youtu.be/A4cHjh2KQyE
Old 01-03-2015, 05:23 AM
  #65
N777CK T's Avatar
Oh yeah I have done 2 oil changes since then! Haha
First one using Castrol Edge:
Second one using Fuchs Titan Race Pro S:
http://youtu.be/8lUP1rnqjWU
Old 01-03-2015, 06:20 AM
  #66
Daytona-Dave's Avatar
Good job your not a college tutor or teaching an apprentice
Old 01-03-2015, 11:19 AM
  #67
CynicG's Avatar
Not trying to flame but I don't see the point in a video tutorial from someone using a garage ramp. If you can lift the car like this, or have access to someone who has a lift, you'll know how to change oil.
I have to inch myself under some jacks for an oil change and work round a cross brace. So accessing the filter from below is total hassle.
Old 01-03-2015, 02:27 PM
  #68
Sparksf20c's Avatar
Originally Posted by BenRNBP
I'd go for the 40 over 30 because in my line of reasoning I'll get better oil pressure when the engine is hot, I tend to pay minimal attention to the Winter number in the UK (especially as I'm in the South and barely go below 0 C for any length of time)
I've always thought the smaller the gap between the two numbers means the chemical engineers have had to use less clever stuff to get the oil to change viscosity so if they did a 10W40 fully synth I'd probabaly go for that.
As it is, I'm happy to take my car to TGM and for them to use whatever they think is best
When I took my car to TGM recently I was curious as to what oil they used and Tom reply was suprising...they actually use 10w-60. They use this in all the s2000 as Tom says it protects the tct. I didnt have enough time to ask about the science behind it (I thought the oil grade was a bit too thick) but I trust Tom knowledge and judgement.
Old 01-04-2015, 04:04 AM
  #69
N777CK T's Avatar
What's wrong?
Why not, it's showing people the problems that they may face when doing it at home...
I understand most people don't have a ramp on their driveway but at the same time having it on a ramp shows people where everything is clearly.
The more people can see / know when they're trying to do it themselves the better.
I now have a decent low profile trolley jack to use in the future - which is one of the points in the video. YOU DO NEED A DECENT TROLLEY JACK!
Old 01-04-2015, 05:53 AM
  #70
Originally Posted by N777CK T
What's wrong?
If your doing it yourself on your own car and haven't got the time to do it properly then nowt, But as you have done it as a how to video then virtually everything, people pick up bad habits from this type as video and pass them on to others and before you know it loads of folk are mistakenly doing it incorrectly (well that's how this guy did it on S2ki )
Quick Reply: Grade of Engine Oil for UK Drivers
