Grade of Engine Oil for UK Drivers
Old 03-27-2014, 01:57 AM
Dembo's Avatar
Originally Posted by Sipha
I've seen 5w30,10w30,5w40,10w40 all recommended lol.
Seems it doesn't make much difference ??
It doesn't make much difference. It's far more important that there's oil in there. It'd be better if more people were anal about checking it, than anal about exactly which brand and grade to use.
Old 03-27-2014, 02:38 AM
Toms1989's Avatar
They recommend 5w40 fully synthetic not just solely castrol edge.
So don't feel like its going to blow up if you use another brand
Old 03-27-2014, 03:18 AM
Scottland's Avatar
IIRC they do actually recommend Castrol Edge nowadays don't they?
I'm using 5-40 Petronas Fully Synth, cheap as chips
Old 03-27-2014, 03:24 AM
UK Moderator
lovegroova's Avatar
FWIW my dealer uses a big barrel of Castrol sumthingorother rather than consumer-branded stuff like Edge.
Old 03-27-2014, 03:43 AM
Sambo's Avatar
Castrol edge 5-40. Costco have an offer of at the moment if you are a member
Sambo's Avatar
Old 03-27-2014, 03:51 AM
cat5cable's Avatar
i use this
http://www.ebay.co.uk/itm/Shell-Heli...#ht_954wt_1163
ginger
Old 03-27-2014, 04:10 AM
N777CK T's Avatar
Wow that Shell Helix is very cheap! Will 5 litres be enough with some left over?
Old 03-27-2014, 04:36 AM
Scottland's Avatar
You'll need 5.5 litres or thereabouts, I usually buy 2 and the rest does me and the other car for top ups as they both take 5W40.
Old 03-27-2014, 05:47 AM
rhauri's Avatar
Local Honda Dealership refused to put 5w40 into a mates S2K and insisted on 0w30.
Hence he went elsewhere, plonkers.
I wouldn't trust Honda with a barge-pole after that and after they changed my coolant and didn't properly bleed the system and the car overheated 2 miles down the road. Annoyingly I picked the car up after the service dept had closed so going back wasn't an option.
Hondata (is that the correct name of the service system?) currently details 0w30 so I'd be wary.
But now I'm straying off topic.
My MY02 drinks Edge 5w40 as if it's as cheap as tap water, so gonna try a different brand next time around.
Sent from my C6903 using Tapatalk
Quick Reply: Grade of Engine Oil for UK Drivers
