Geometry Settings...
#21
Originally Posted by mikey k,Oct 15 2005, 11:45 AM
Front castor is a little unsymetrical but other than that
#23
Originally Posted by indigoblue73,Oct 16 2005, 07:27 AM
Could this cause the car to pull to one side? Also still wondering about tyre pressures...
#24
[QUOTE=indigoblue73,Oct 15 2005, 06:01 PM] Just had the geometry done on the S to the revised settings.
The car now seems to slightly pull to the left now... Could this be caused by the difference in the castor (see below)? Should I take the car back to get them to sort out the difference or is this acceptable?
I will double check the tyre pressures tomorrow... Can any one recommend a tyre pressures for Goodyear GSD3s (had these fitted a few weeks ago).
Camber Actual Recommended
Front Left -1
Front Left -1
#25
The toe has both wheels off to one side... so with the steering wheel straight, you'll be truning slightly. Nothing to do with the castor. It's also slight, so I wouldn't expect most drivers to notice that little. I'd check the tyre pressures etc first.
-Brian.
-Brian.
#26
Mine used to chase the camber a bit more when the castor was out like that.
It was great in the fast lane or in Europe - straight as a die. Bad on our off-camber roads.
If you complain, they may get things more even at the second attenmpt!
BSM139
01-27-2005 07:01 AM
