Geometry
Old 06-25-2007, 09:22 AM
motogp1's Avatar
Originally Posted by RobJ1,Jun 25 2007, 04:49 AM
The only place people will recommend on this site is www.cofg.co.uk
Center of Gravity
I have never been myself but I am booked in on the 14th July.
Book yourself in but also check your tyres. Check the presure, the sizes and the tread. Make sure you have the same tyres on the same axis and you should be ok till your visit to Center of Gravity.
im booked in on the 15th i ,
chris answer you emails
Old 06-25-2007, 09:32 AM
RobJ1's Avatar
Hope he doesnt think mine is going to take all day !
Old 06-25-2007, 09:33 AM
Administrator
AquilaEagle's Avatar
Originally Posted by lalakis2000,Jun 25 2007, 02:36 PM
Now that the issue has been brought up, I was wondering if any of you gentlemen could confirm that the UK geometry settings for MY99-03 in the FAQ can be applied to MY 03 s2k that has swapped wheels to 04 OEM (17in).
Thanks in advance.
Yes they can
Old 06-25-2007, 09:56 AM
mikey k's Avatar
Call him on his mobile, best way to get to him.
He is too busy under cars to be at the PC
Old 06-25-2007, 10:04 AM
motogp1's Avatar
tried that and left a message
i know he will get back to me in good time
(cusco rear lower arm arrived today so that will be fitted soon )
Old 06-25-2007, 10:10 AM
martin j's Avatar
Originally Posted by lalakis2000,Jun 25 2007, 03:12 PM
Anyone?
(help, it's 43C in Athens, I can barely type)
And you expect sympathy.............. 43*c lucky toad.
Old 06-25-2007, 11:20 PM
lalakis2000's Avatar
Sorry, I meant 45C.
A million thanks to AquilaEagle for his reply.
A nice day to you all. I am going to pass away now...
Old 06-26-2007, 12:38 AM
MC_BLADE's Avatar
Originally Posted by RobJ1,Jun 25 2007, 02:52 PM
Or even better, go to Chris first and then get new tyres.
Chris can read your tyres to help find out whats wrong with your car.
I thought that Changing tyres makes a difference to the Geo as the car is ajusted to get the right amout of tread on the ground etc so you Should get it done on a new set what arnt worn, rather than leave the unevenly worn ones on and change them after the set up???
Seams to make more sense to me
Old 06-26-2007, 01:01 AM
Dembo's Avatar
Originally Posted by MC_BLADE,Jun 26 2007, 09:38 AM
I thought that changing tyres makes a difference to the geo as the car is adjusted to get the right amount of tread on the ground etc., so you should get it done on a new set that aren't worn, rather than leave the unevenly worn ones on and change them after the set up???
Seems to make more sense to me
Not really. The optimum setup will vary according to tyres, yes, but you can't sensibly allow for that, at least not without going lots of times.
If you go along with worn tyres, Chris can get information about the way you drive and the current setup by looking at the tyre wear (one of the things that makes going to Chris a lot better than Honda or most others).
Old 06-26-2007, 02:37 AM
Si2000's Avatar
Thanks everyone, some useful info there!
After my hols in a couple of weeks, I'll get the front tyres changed, and book it in at C of G. I'll also take the old tyres with me for Chris to have a butchers at.
I think I also might have a leaking valve on the nearside rear tyre, I'll get that sorted out before taking it C of G too.
I can see me going and getting four new rubbers at this rate!
Si
Sorry, forgot to ask how much it'll roughly cost at C of G?
Spies
12-15-2009 01:21 PM
Survey S2000
05-22-2009 09:02 AM
Bradleynorth
11-04-2007 10:26 AM
johnnyb
05-18-2007 02:10 AM
moff
01-26-2004 10:41 AM
Quick Reply: Geometry
