Geometry on 04's
Old 06-12-2005, 12:49 PM
mikey k's Avatar
Thumbs up Geometry on 04's
So I am trying to work out if there is any difference or benefit to applying the 99-01 optimum geo to an 04 car?
Any one had the geo done on a 04 shape?
Old 06-12-2005, 02:24 PM
chilled's Avatar
I've been asking a related question and apparently the 04 requries a different geo because the rolling radius is different. I don't know if it's true but I've heard several people say that the 04 would require 245/35/17's to match the rolling radius of the 16's
Old 06-12-2005, 02:26 PM
Fieldl's Avatar
We had a chat about this yesterday over lunch.
I need to have the Geo done when I get the tyres done......
Will go for the standard 04 setup. Trust me it won't hold you back
Old 06-12-2005, 02:41 PM
ade73's Avatar
The suspension set up is different Mike and so the 99-01 Optimum geo is not the one for an 04>
Old 06-12-2005, 02:45 PM
Beardie's Avatar
So will the stealers have the correct info for the geo setup on 04>'s?
Old 06-12-2005, 03:01 PM
ade73's Avatar
They should do, but as its Honda they will use the ones from a Jazz
Old 06-12-2005, 03:07 PM
Beardie's Avatar
That's what worries me. We need the official settings.
Think the septics have found them?
Old 06-12-2005, 03:31 PM
chilled's Avatar
Well on Anglesea I could match any other S2000, but I welcome more challengers. I will remain stock to help any would be challengers.
Old 06-12-2005, 11:20 PM
Bassoctopus's Avatar
They're in the faq...
MY04
Camber front: -0deg30' +/- 10'
Camber Rear: -1deg30' +/- 10'
Caster front: 6deg00' +/- 15'
Front Toe-in: 0mm +/- 2mm
Rear Toe-in: 3mm +/- 2mm
Front Wheel Turning Angle Inside Wheel: 34deg00' +/- 2deg
Front Wheel Turning Angle Outside Wheel: 29deg (Reference)
Old 06-12-2005, 11:46 PM
mikey k's Avatar
I knew they were in the FAQ but I am curious to know if any one has had any different set ups or if they can be a applied to a car with 18" Volks on!
Quick Reply: Geometry on 04's
