Geodesy problems
Geodesy problems
Nothing but problems since jan when I upgraded to "plus"
Wouldnt upload, down load whatever.
Sent it back twice.
Came back and the unit now looks decidedly second hand. The perspex has gone slightly opaque and there is black paint on where they have "fixed" it.
Worked for a couple of trips and now fails to get on line with the satelites.
All the time Morpheus have been prompt but less than straight, never acknowleging there was a problem.
I now have a
Sent it back twice.
I now have a
Originally posted by rudester
Got the Origin.
Had this problem
or do anything. Called them - they were aware of the problem with a few units - sorted it v quickly.
Been fine ever since
Thought I had this problem after updating the database. Fiddled around and discovered I hadn't plugged the antenna in far enough. Now make sure it's pushed firmly home. No problems.
Don't know what the Morpheus antenna connection is like???
Got the Origin.
Had this problem
Glad Origin managed to sort it out for you.
The Geodesy has the antennae built in. Had good line of sight to the sky as the roof was down.
How well does your device work, Im thinking of getting one if this saga continues.
I use a Radar detector on my s2000 and on my fireblade and they work excellent. They pick up gatso, hand held and mobile the only thing they will not pick up is the vascar which is an electronic timing device so just keep an eye out for the white lines at the side of the road.
Originally posted by mikerich
but then I found the thing on a Renault I had which kept telling me my 'oot was open quite charming
What is a 'hoot' anyway
