Gearbox rebuild?
Old 11-25-2019, 01:01 PM
Bluejack's Avatar
Originally Posted by Irish TuneR
Not sure that service bulletin would help since an AP2 gearbox is different to an AP1 which is what Europeans have. Could have the same internal part as gears 1-4 i believe are the same, 5/6 are longer and the secondary shaft is different.
So still trying to get to the bottom of this, thanks for your comment.
So the secondary gear set in the TSB, Part no. 23432-PCY-316, wouldn't work with a UK spec 2005 car, but only an AP2 gearbox? Is that right?
Old 11-25-2019, 02:02 PM
Nottm_S2's Avatar
try googling that part no, i found threads talking ap2 only in a 5s search
https://www.s2ki.com/forums/s2000-un...-336-a-889280/
Old 11-26-2019, 01:02 AM
UK Moderator
UK Moderator
lovegroova's Avatar
This might help.
All UK cars use AP1 engines and gearboxes.
The AP2 is the 2.2 litre engine which only has 8,000rpm but more torques and uses a different gearbox and different ratios.
anyway,
Here's a diagram of a UK 2005 Gearbox along with part numbers:
https://www.lingshondaparts.com/part...ckref/M__0500/
I'm pretty certain that the service bulletin does not apply.
Old 11-26-2019, 01:21 AM
martin j's Avatar
Originally Posted by lovegroova
This might help.
anyway,
l know someone building a kit car using S2KI engine and box, he’s interested in what the difference in the ratios are, ie is the us box 5th and 6th better suited to cruising, using less revs at m/way speeds? NVH levels are pretty high in some of these things.
Old 11-26-2019, 03:15 AM
UK Moderator
UK Moderator
lovegroova's Avatar
It's all on Wikipedia.
Scroll down to the Specifications Table https://en.wikipedia.org/wiki/Honda_S2000
Here's the AP1 gearbox:
1st: 3.133
2nd: 2.045
3rd: 1.481
4th: 1.161
5th: 0.970
6th: 0.810
Secondary gear reduction: 1.160
Final drive: 4.100
Reverse: 2.800
And the AP2:
1st: 3.133
2nd: 2.045
3rd: 1.481
4th: 1.161
5th: 0.943
6th: 0.763
Secondary gear reduction: 1.208
Final drive: 4.100
Reverse: 2.800
Note that, while the ratios are the same for the first 4 gears, the difference in the Secondary Gear Reduction 1.160 vs 1.208 means that the AP2 gearbox is shorter for the lower gears but longer for the top 2.
Here's a useful table of the max speeds in each gear for the various options:
https://www.s2ki.com/forums/s2000-un...-info-1124653/
martin j (11-27-2019)
Old 11-26-2019, 10:32 AM
Bluejack's Avatar
This might help.
anyway,
​​​​​​Thanks, familiar with the AP1/AP2 differences but that link to Lings is useful, thank you. It looks like the relevant part number is 23618-PCY-326, so you're right in that the part numbers in the TSB don't appear to apply (presumably because it's a US TSB and they used different part numbering for whatever reason?). Some more googling does suggest that 23618-PCY-326 replaced 23618-PCY-316, and that 326 strictly speaking applies to 2006 cars onwards.
I wonder therefore that there may be truth in the TSB, but these different part numbers apply.
Old 11-27-2019, 01:44 AM
UK Moderator
UK Moderator
lovegroova's Avatar
Part numbers are the same across the world.
It's just that the US AP2 cars have a different part in this case, and it's that different part the TSB applies to. It does not apply to UK cars.
FWIW, here's the diagram for the MY02 car
The equivalent part no is 23618-PCY-306
And it's the same part for an MY00 car
23618-PCY-306
So for UK cars you have either 23618-PCY-306 or
23618-PCY-326.
If you want to look up US Part numbers, you can do so here:
https://www.hondapartsonline.net/
US 2002 https://www.hondapartsonline.net/v-2...countershaft-1
23432-PCY-306
US 2005
23432-PCY-336
US 2009: https://www.hondapartsonline.net/oem...BlZWQtbWFudWFs
See the note which says:
Replaces: 23432-PCY-316, 23432-PCY-326
So, in summary:
All pre-2004 cars use 23432-PCY-306
UK post 2003 cars use 23618-PCY-326
US post 2003 cars use
23432-PCY-316 which was replaced by 23432-PCY-336 It's these cars that are affected by the TSB
Old 11-27-2019, 10:16 AM
Bluejack's Avatar
23618-PCY-306
23618-PCY-326.
23432-PCY-306
US 2005
23432-PCY-336
So, in summary:
Cheers, appreciate your time on this!
I agree with all of that, the only bit I'd add is that it still looks like UK 2005 cars had 23618-PCY-316 replaced by 23618-PCY-326, similar to the US situation: www.parts-honda.uk/honda-cars/S2000/2005/S2000/TRANSMISSION/COUNTERSHAFT/17S2A01/M__0500/2/20733
Old 11-28-2019, 01:38 AM
UK Moderator
UK Moderator
lovegroova's Avatar
I wouldn't trust that site, it's French
Old 12-30-2019, 06:09 AM
Bluejack's Avatar
of the symptom just for records. Will be picking up with transmission specialists in the new year to get some advice and quotes.
Quick Reply: Gearbox rebuild?
