Gearbox problems on 05 car?
My 05, 55 plate S - 17k on the clock, seems to catch going in to 2nd gear (going up the box) at low revs - at any thing above 4-5kish on the revs it seems to be absolutely fine. Also, when I come back down the box in to 2nd, e.g if I were going to overtake some one at low speed, if I am doing any thing more than 25-30mph, it quite often pops out of 2nd gear. Just to be clear, this does only happen when I come back down the box and not going up.
I have booked the S in to my local dealer - 2 mills Honda for next Friday, 11th April as it is still under warranty, but don't want to be fobbed off.
I have searched through the technical data/help on the website but can't seem to find any thing that seems to be related to my problem, any ideas what it could be?
My 05 is sometimes an effort to clunk it into second from first, especially when cold, and occasionally pops out of first if I haven't engaged it properly. Shower it to Honda Ewell who drove it about and counldn't find anything wrong...
You have triple-cone synchronisers on 2nd; it's always more deliberate a shift than the other gears.
It's to protect the synchro against those who cannot H&T down the box.
Early cars would 'crunch' if you rushed the shift, so there was a recall for those who complained.
The corollary is a worse change.
If it's anything more than that, you have a specific problem.
Will see what Honda come back with and PM Markwneale to see what happened with his. Seems to be a common thing from the responses so far and is definitely more prominate when it's cold as a few of you have mentioned.
Thanks for all the replies!
To be fair it's hardly noticeable when it's warm.
Mine used to do the same thing sometimes. In your next transmission oil change try this and you won't regret it
transmission oil
Mine is like butter now
Chris (blue monster too )
transmission oil
transmission oil
transmission oil
