Gearbox oil change
Hi,
I'm due to change the gearbox oil, I have 1.8 litres of amsoil here having previously put in Redline, I think I've only done 15-20k but gearbox is a little notchy.
I am correct in thinking I undo the drain bolt (bottom bolt) first let it drain, put the drain bolt back in and then remove filer bolt and fill up a smidge under level with the bottom of the filler hole? Then put filer bolt back in?
I don't have a special tool to fill, what can I use other than buying something? as I've left it late to order a filler suction etc device for Saturday.
IIRC there's enough room to do it with the car jacked up?
Are there bolts magnetic?
Thanks in advance
Thanks in advance
Hi,
Thanks in advance
Thanks in advance
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Undo top bolt first, then the bottom to let oil out.
Bring a funnel with you to B&Q and buy some clear tubing that would fit to the end of it. 1.5 meters of tubing is more than enough. Feed the tubing from engine bay to the top filler hole and let gravity do the work.
I use a pump to get the oil in.
Drain wise, just undo the drain bolt.
Fill the oil up until it comes out of the fill hole.
Tighten it all back up.
http://www.ebay.co.uk/itm/New-SIPHON...item4839637b0d
As above I'd remove the filler first to make sure I could refill the box, and it makes the oil run out easier, I usually wait till it stops dripping and then add a little fresh into the box then waiting for it to run out, hopefully taking any old oil (hiding in hidey holes) with it.
And do it after a long run.
Nice and warm on your handies![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
I do not think the gearbox drain is magnetic, but I seem to recall the diff one is?
I used amsoil MTF in mine and there was a notable improvement in cold shifting.
