Gearbox oil
Gearbox oil
Hi Chaps, i have noticed the gearbox seems a 'bit' more notchy than usual
TBH i cant 100% remember when i last changed it but it must of been around 20k miles ago, do you think i should change it or will it make F.A difference??? I'm off work tommorow so i could do it - I thought the schedule was quite a bit more than 20k!!??
Gearbox was replaced by previous owner @Honda though this was over 4 years ago
First thing just to check I'm correct when replacing gearbox oil its 75W90 and requires 1.5 litres?
Last time i used Motul stuff.
Thanks in advance
AJ
Thanks in advance
AJ
P.S
I used Motul last time, but is there any other brand(s) people recommend if i do change it I'll have to get some from a shop NOT honda (bit far away even though there stuff is generally good).
My 5th gear used to crunch when doing full boar 4th to 5th changes.
Since changing to Castrol SMX-S, it hasn't any more
Really nice smell to that SMX-S too
When are you supposed to change the gbox oil at what mileage? according to the FAQ service sheet its 72k miles?
Whats rating of the castrol smx? 75w/90?
Originally Posted by Ajs_s2k,Jun 2 2009, 09:30 PM
Might give this a shot then? you reckon its worth it and will help notchiness Ron?
Since changing to it I have really noticed an improvement!
Personally, I change my gearbox/diff oil every 2nd engine oil/filter change which works out every 8-9k miles
If you use Amsoil 5W-30 you will never go back to any other tanmission oil
https://www.amsoil.com/storefront/mtf.aspx
Redline is a very good choice too for diff oil . I use LE for my diff. It supposed to be one of the best but a bit expensive though
Do not know about Castrol in transmission so i cannot comment
