Gearbox & Diff plug washers
What is the size (ID/OD/Thickness) and specification (copper or Alu) for the two gearbox plug washers and the two diff plug washers.
Want to get these ready for draining & replacing oils with Motul G300 & 90PA
Phil
Phil
Its always best to replace the washers, don't cost lots, if you don't and they start leaking you have to do it again.
Don't know how much they cost but the bolts need to be set at:
G/Box 39N.m 29lb
Diff 45N.m 33lb
Dave
G/Box 39N.m 29lb
Diff 45N.m 33lb
Dave
G/Box 39N.m 29lb
Diff 45N.m 33lb
G/Box 39N.m 29lb
Diff 45N.m 33lb
Anyone?
Administrator
it would certainly be a good place to start
or the parts catalogue
check here:
http://www.slhondaparts.com
check here:
