Fitting Alpine Headunit
The Aerial doesn't fit.... I guess I can get a standard conversion connector somewhere?
My KCE-865B works for the volume, CH, mode but the mute button does nothing (it does light up when pressed)... is this normal?
Other than that, it went ok. Not much room behind the stereo is there!
Double check:
"Connect the pink/black striped wire from the stereo loom to the peach coloured wire (labelled Tel Mute) from the adapter loom. This is the mute/interrupt signal from the dash control."
https://www.s2ki.com/forums/index.php?showtopic=268241
it's now resolved, after a bit of time using the search function the ideal solution appears to be
www.modifry.com
www.modifry.com
www.modifry.com
www.modifry.com
All sorted.
Aerial adaptor sorted - 3quid!
Moved the peach wire unto the pink/black and the dash controls all work perfectly.
Thanks all for the help Thats whats great about this place.
