first time let down
first time let down
ah well almost three years to the day since i got her and my s has let me down. wouldnt start last night in a freezing car park in the middle of nowhere. battery fine. press button nothing at all happens, like the immobiliser is on. called the rac (rejoined the rac) and they came out. contractor with flat bed tried to jumpstart which i didnt expect to work and then loaded it on the flat bed and took it away. quite sad to see it look so forlorn.
anyway anyone got any ideas what could have caused this? just so i have some ideas when the garage call me to tell me the damage. car tax due this month too gulp
Is the dash lighting up as normal when you turn the ignition on?
If it is i'd be checking the signal wire to the starter motor. Its fitted with a spade connector that just pushes on. I was amazed how loose mine was when I replaced my starter motor, it could have easily come off.
My guess is Main Relay
This is usually the cause on other Honda's (Integra's and Civic's) in the freezing cold, so before you spend too much getting the garage to do anything major try that.
worst thing is i have fixed this on my car before... i think the cold last night must have affected my memory. i called the garage this morning and asked them to check it and it was disconnected.
cheap fix thankfully just need to get to montrose now!
cheers
Originally Posted by arab,Jan 12 2011, 02:16 PM
we have a winner :-)
cheap fix thankfully just need to get to Montrose now!
cheers
cheers
s2kslav
10-17-2011 10:12 AM
