Fault code reader
Fault code reader
anyone know how to use a fault code reader. Mine has arrived so plan to hook it up and check the code for this warning light I have
No idea where it goes, tried a search on forum but in a bit of a rush so didnt have time to traul through 71 posts
cheers
cheers
UK Moderator
The OBD2 port is next to the centre tunnel on the passenger side, just under the plasic cover (just above the cargo net thing) - have a crawl around and you'll see it ok.
The OBDII port is on the passenger side. Its in the top of the footwell very close to the Radio. It faces downwards and is not covered. Grab a torch and you will see it.
Update is - the engine light went out for a while, but has recently come on again. I connected the OBD2 to the connector and it keeps saying linking error
Can't seem to find the bloody instructions for this thing now, anyone know what I am doing wrong?
http://www.crecorder.com/website/use...uctInfo&page=1
Yours is an 06 S2k, Honda updated the spec to EOBD2. You can pick one up on fleabay.
EDIT - non on ebay in the UK but loads if you search from £49 to £60
