eps reset?
eps reset?
Hi guyz, does anyone know the procedure to reset the eps? I thought ill give it a go as my eps light remains on and theres no power steering. Thanks in advance
Try this fella
A few things to try in here, hitting bits with spanners is always a good idea.
https://www.s2ki.com/search/forums?query=ep...forum=25&topic=
Edit... this one looks easiest to try first
https://www.s2ki.com/forums/index.php?showt...0&#entry8841640
Make sure you know your radio code.
If the light fails to disappear after resetting the ECU, hit the EPS unit with a screwdriver or something not too heavy a few times. It's the gold unit on the drivers side in the engine bay with 'Showa' written on it.
Dug up another post which says just drive it for a bit.
https://www.s2ki.com/forums/index.php?showt...onths%20of&st=0
Hope you get it sorted.
hi there again, well i tried all these things today mentioned in previous posts but with no luck. Seems like i need a new steering rack as my eps motor has a short circuit. does anybody know where i can get hold of a steering rack?
Nope.
I'm afraid at the risk of the mods beating me up.. I'm going to say it...
1/ Try the search function. Someone must have done it before.
Be brave and spend an hour or so searching through the posts.
2/ Ask Garage R for what they sell.
3/ Put up another post ( also mention where you are ) - someone locally is bound to help.
