EPS Problem or not a problem?
Hello Everyone
Was drawing codes for the Engine Check Light and noticed the EPS is also flashing.
Strangly enough the EPS never comes on while I'm driving or the engine is on and the steering isn't heavy and has no issues.
Regardless I've got the following codes from it:
23
34
According to an old post by MB they are the following:
DTC: 11 Difference of high voltage and lower voltage on the torque sensor
DTC: 21 A problem with the voltage for lG1
DTC: 23 A problem with the circuit for engine speed signal
DTC: 34 A problem with the main microcomputer
Is this actually a problem or should I ignore it
I have the SPOON SPORTS ECU which could be why?
Like I said the steering isn't heavy or anything and is very reactive and EPS never comes on the dash unless in diagnostic mode.
Many thanks for your help!
Joe
23
34
Joe
