Eps light on no power steering
I'm thinking more like this unpainted clip.
-- Chuck
-- Chuck
Bummer.
All the procedure does is memorize the Torque Sensor Neutral Position which seems a common cause of the EPS light on the dashboard. The Service Manual (US) has the same procedure using the Honda Diagnostic System (HDS). The SM has extensive trouble shooting information all of which depend on the HDS and may only be applicable to US/CDA cars. A couple dozen trouble codes listed. Got access to the UK/EU manual? There was one offered on CD here a couple of years ago. I have it on a laptop as a virtual drive but darned if I can access it this morning.
-- Chuck
-- Chuck
One of my pals does have a s2000 manual.. will look at that over weekend..
checked both ends of rack and nothing is bent, just tracking slightly out but need allignment to sort that..
Just driven the car on a loop distance of 10 miles.. managed to fix the cam sensor wiring.. does feel good to have engine running again and vtec
you just need a good reader
i have the Honda OEM one but you aint local
why where do you live on the moon, 99% of garages will have a scanner that will plug on,,better than sticking clips and wires into sockets because Freds brothers uncle said so on the internet
