Engine went Bang!
Old 02-14-2008, 04:28 AM
  #41
j8mie's Avatar
Originally Posted by chrisr111,Feb 14 2008, 12:08 PM
Yes Jamie, from memory the manual states 13lbft but this was later revised and a bulletin issued stating that they should be torqued to 18lbft. You can do the math to convert to NM.
Edit:
18lbft = 25Nm so your plugs are ok.
Chris.
ta
Old 02-14-2008, 09:36 AM
  #42
Dox
Dox's Avatar
You could try these
http://www.timesert.com/
Old 02-15-2008, 12:10 AM
  #43
jonner's Avatar
That some dent in the bonnet....
Old 02-15-2008, 12:27 AM
  #44
C&S Evo7's Avatar
I can probably fix this for you,
i have a special kit which rethreads the hole then a steel insert is fitted into which the plug fits,
it is better to get the head off to do,
I used to race an old jaguar engine with high comp on methanol i had a problem with the alloy of the head being too soft so got the insert kit.
i will check the sizes of the inserts i have, if correct and you can get the head to me it will take no longer than 10 mins i'll do it as a favour.
they are very similar to the post a couple up Timesert
Old 02-15-2008, 02:04 AM
  #45
C&S Evo7's Avatar
I have checked the kit. If the plugs are 14mm thread (my dc5 are) i have a full range of inserts. So would be confident i could repair this for you.
Old 02-15-2008, 02:14 AM
  #46
eho
eho's Avatar
C&S Evo7 you dont happened to live near Milton Keynes do you?
Old 02-15-2008, 05:58 AM
  #47
C&S Evo7's Avatar
Sorry bristol.
Old 02-15-2008, 06:09 AM
  #48
m1bjr's Avatar
Originally Posted by MC_BLADE,Feb 14 2008, 10:19 AM
you can if its not too bad just helicoil the block in situe, the head is alu so the fragments wil just burn up in the engine anyway
Hunt about for a GOOD machine shop.
You can fill the head with something (like shaving gel) with the piston at BDC.
Make the insert (one piece sleeve like type best as no tang to snap off) and simply rotate the engine over TDC to expell the swarf. As mentioned, alloy is not too big a deal - recovering a tang end of a traditional helicoil is.
If done properly and bonded in you should get away with it for years and ought to cost less than
Old 02-15-2008, 07:04 AM
  #49
C&S Evo7's Avatar
Sorry for some reason i thought the head was already off. It is perfectly fine to do in situe and always did it this way before . If you were prepared to spend 100 quid. I will come to milton k and do it at your house or wherever the car is. I would not use a helicoil because of the previovsly mentioned tang being difficult to remove afterwards. I have sleeve type inserts. We used to use some really expensive expanding foaw type stuff. Never thougt of using shaving foam . Good tip.
I could do it this weekend too
Simon
Old 02-15-2008, 09:27 AM
  #50
MB
Member
MB's Avatar
Hi Simon - might be best to PM your mobile number in case it gets spammed.
Quick Reply: Engine went Bang!
