Engine went Bang!
Old 02-13-2008, 03:13 PM
RISLAR's Avatar
Originally Posted by chrisr111,Feb 14 2008, 12:10 AM
I see from your sig that you had non standard plugs fitted, you didn't torque them to the setting in the service manual by any chance?
Chris.
I was just gonna say that, this has been way to regular !!!
Old 02-13-2008, 03:16 PM
eho
eho's Avatar
i feel shitty atm, wheres that ice-cream when you need one
i guess i need to ring around, see what kind of price im looking at. my boss arent going to be happy as im gonna need a few days off during the most inconvenient time.
Old 02-13-2008, 03:50 PM
*AL*'s Avatar
Ouch, feel for you matey.Should we all be checking our plugs now? How long ago did you last have the plugs out?
Old 02-13-2008, 09:42 PM
oxhouser's Avatar
What you need to ask for is a heli coil insert fitted, this looks like a tight spring but in fact is an insert with thread on inside and outside, the block is drilled and tapped to the outside thread dia then the insert is fitted using permanent lock tight. Its a permanent solution and should give you no problems in future but you will have to remove the head to do it.
Old 02-13-2008, 11:07 PM
Administrator
AquilaEagle's Avatar
Denso?
Old 02-13-2008, 11:21 PM
jonner's Avatar
Had an engine blow up there not so long ago so i know how you feel....My own feelings is the honda wont give you any sort of help what so ever even if they do the work...
Hope you get it sorted soon man...
Old 02-13-2008, 11:31 PM
eSeM's Avatar
Originally Posted by AquilaEagle,Feb 14 2008, 08:07 AM
Denso?
NGK
RTFS
Old 02-13-2008, 11:35 PM
alex.stanley's Avatar
I think I need to check my plugs - I didn't realise this was affecting '04+ models!
Old 02-13-2008, 11:36 PM
eSeM's Avatar
As far as I am aware *all* models have spark plugs.
Old 02-13-2008, 11:54 PM
j8mie's Avatar
Chris.
Can you clarify this post Chris. Are you saying they should be tighter than stated in the service manual or not?
I checked mine yesterday and I torqued mine to 25Nm as per the manual so I'm looking for clarification myself.
Quick Reply: Engine went Bang!
