Engine weights
need to post a price for these "Engine Weights" I'm afraid.
What sort of gains can I expect to see? Will they fit an AP1?
ok ok i'm sorry, slow news day...
*edit* to qualify the above nonsense - this was once in the FS section
The F20C is by far the heaviest of them all and as such should only really be in a production car, like the S2000, instead of being removed from the circle of life and sentenced to a short horid existance in a kit car.
Define Engine, if you include the stock fly, manifolds and fluids then 150KG+ for an F20c.
There are a few Lotus related sites that compare the S2000 engine against others like tuned Rover K series engines.
150kg sounds on the heavy side.
I know a comparable engine (Dual over head cam with variable valve timing and variable lift systems using aluminium block and head) is approx 100kg complete with oil fill, intake and exhaust manifolds and clutch plate/cover/flywheel assy
Theres a thread if you search regarding a k series engine it was by me quite a bit ago. On the webpage it discusses various engines including the f20c and K series, IIRC it was ~110kg without fluids but i cant be sure.
Originally Posted by fluffyninja,May 23 2010, 05:48 PM
It tells you on that web page under 'engine weight comparisons'.
Stealth Operator
04-11-2020 12:48 PM
