Engine Noise
#21
Sounds like a diesel!
Cold it still doesn't sound great either. Give HUK a call and get them to have stern words with the dealer. SHocking service.
PG
PG
#22
First thought was a cracked exhaust manifold....
That amount of clatter, very reminiscent of a timing chain.
I had the same noise on bike engine I damaged, broken up top piston ring and land.
Little rough at idle, okay on song, used no oil as oil control rings still intact.
Compression would be down a bit though....
Steve
Steve
#23
I thinks the sound is enhanced by the fact that the rocording was done indoors although it can clearly be heard from within the car when driving alongside walls, high kerbs etc that reflect the noise. Compared to my last (2003) S2000 which I also had from new, the cold sound is fine and no different.
Steve
Steve
Thanks everyone for your help. I was looking for advice from those with direct experience of the 09 noises and I'm grateful to those who have taken the time to post and contact me directly via PM
#26
Thanks Kiteland
The current position with my car is that like Kiteland's car, the thrust washers have been replaced, the crankshaft end float is back in tolerance, but the noise has returned after only 100 miles.
I see THIS post from Kiteland (clicky) as very positive news indeed, and I am patiently awaiting the outcome of Honda Japan's investigations.
So that we do not end up with multiple threads discussing this issue I am closing this one now
