Engine Light & EPS Power Light on
Hi All,
Needed some help and explanation about some warnings lights on in my car. The Engine Light and EPS light was on in my car and I took it to my local honda garage to have it checked out, they reset it charged me
Member
Hello!
Can you clarify what lights came on? Did you get the yellow one which looks like an engine (CEL) and the EPS light?
As Ian says, they shouldn't really charge you for this - my dealer did it free until I got my own monitor for
Hi Mark,
Yeah the yellow engine one came on with the EPS light.
It hasnt had a new battery but when I got the car the RAC check guy mentioned the battery wasn't in mint condition and he said my need replacing? Nothing else has been serviced, next one in due next Feb.
I have recently fitted a new headunit and door speakers and an amp but this is not connected to the battery or anything at the moment.
Think they got the air pump code wrong!
Member
Well they may be right on that code as the P1411 and P0411 are both air pump related. Given they are electrical im wondering if your pump has seized and is drawing excess current?
When you start the car from cold, does the air pump run for about 30 seconds or so, then cut out? You can hear it if you stand at the fron passenger side and listen down by the headlight. When it cuts out you will hear a wheezing noise.
Best I can suggest im afraid!
Will look up those other ones and see - but I suspect they are a result of something on the air pump.
MB
MB
Cool, will give that a go at home where its a bit quieter.
The EPS light also sometimes remains off when I start the car but then comes on after a while, giving me no power steering!
Member
Just realised - doh! All the bottom 3 are individual EPS codes rather than CEL codes.
This thread is well worth a look:
https://www.s2ki.com/forums/index.php?showt...52&hl=eps+light
EPS codes -
DTC: 1 Power relay stuck ON
DTC: 2 Fail-safe relay stuck ON
DTC: 3 LOW FET(Motor drive transistor)stuck ON
DTC: 4 UP FET(Motor drive transistor)stuck ON
DTC: 5 Open to body ground in the motor circuit
DTC: 11 Difference of high voltage and lower voltage on the torque sensor
DTC: 12 A problem with voltage for torque sensor VT3
DTC: 13 A problem with average of voltage for torque sensor VT1 and VT2
DTC: 14 Open or short to body ground in the torque sensor circuit
DTC: 21 A problem with the voltage for lG1
DTC: 22 Excessive change of the vehicle speed sensor signal
----------A problem with average for vehicle speed and engine speed
DTC: 23 A problem with the circuit for engine speed signal
DTC: 30 A problem with the sub-microcomputer
DTC: 31 A problem with the initial current sensor offset
DTC: 32 A problem with the main current sensor offset
DTC: 33 A problem with the current sensor
DTC: 34 A problem with the main microcomputer
DTC: 35 A problem with the sub-microcomputer
DTC: 36 A problem with the change of the motor voltage
DTC: 37 A problem with the motor voltage
MB
MB
EPS codes -
MB
MB
