Engine fault codes - Where do I go from here?
One the way home tonight I get the CEL light on.
Check the codes and they're P1399 P0300 P0301 P0304 so all related to misfires.
So I thought I'd reset the ECU and see if they come back tomorrow.
When going through the idle learn procedure I get the CEL light on again only this time it's flashing. 12 flashes then constant for a min or two then repeat.
Engine off and check the code, another P1399.
What should I check first?
.....help....
.....help....
Wayhay, the search function ROCKS.
https://www.s2ki.com/forums/index.ph...ic=479278&st=0
...and even better than that, same codes, same symptoms and......
SAME CAR!
I bought it off Itchy a while back so off to repeat his carb cleaner trick!
SAME CAR!
Originally Posted by mikey k,May 11 2009, 10:20 AM
BTW codes are in the FAQ
Anyhoo, 20 mins of carb cleaner and rag and engine revving and more carb cleaner and....
I swear I have another 10bhp !!
Totally different. Lovely throttle response and definitely more power. It was like thick black goo everywhere. I must have used half a can of carb cleaner and half a kitchen roll.
So all resolved thanks to the use of the search function.
Let this be a lesson to all the newbies.
