Engine Cleaning
Engine Cleaning
Having had my car for a while now... and using it everyday, i am looking to get my engine steam cleaned..
Although it is not too bad, i can see the dirt building up.
Can anyone recommend somewhere close to to bristol who can do a good job???
I can't recommend anyone but from what i've read steam cleaning may not be the best way to go. It's not too difficult to do yourself check out page 7:
http://home.comcast.net/~michael.cohen1/De...g_Hand_Book.pdf
It only takes around 1-2hrs maximum.
Just remember not to try covering the battery with baking foil!
I'd rather have a slightly 'dirty' engine rather than jet wash or steam clean it.Obviously it can be done but can also lead to electrical glitches and/or squeals if not done carefully.
Administrator
Just jetwash it yourself. Cover all the bits you need to with cling film and do it when warm. Jetwash, remove film and run engine on idle to dry
Use CD2 Cleaner and engine detailer, it is great
This is a Honda; not some Eurocrap!
The Kaercher provides a fine mist, which seems to dissolve dirt effectively, a bit like steam. Obviously keep your distance so you don't damage anything & dress with interior plastic spray & an old T-shirt:
I've steam cleaned plenty of car engine bays, and as long as you stay away from pointing directly at the fuse box or other electrical items, you'll be fine.
Can anyone point me in the direct of who sells it?
