ECU Reset ?
ECU Reset ?
Having made a recent S2K purchase I have been treating my S to tankfulls of Optimax. I understand it is a "learning ECU" and will learn to use the benefit of the higher octane petrol to provide more power and better driveability.
Having had a Scoob in the past, the story with these was that it also learnt your driving style. There was a procedure to reset the ECU, then you would brim it with Optimax and then thrash the nuts off it for a while !
Is this the same in the S and is there any advice out there on getting the best from the standard ECU ?
Cheers
Member
Same really, ECU will learn quite quick. Its the same theory knock control the ECU uses - less of an issue with an NA car though, and its designed to run on 98 anyway.
MB - fellow multiple scoob owner
PS - scoob ECU's dont learn you're driving style - thats reserved for high end german stuff They learn fuel quality etc, as per most cars.
Originally Posted by s2000silvervtec,Aug 22 2005, 05:29 PM
To reset your ECU take leads your batt and wait a few secound and the replace thats it!! Well thats the way i have done it.. works for me.
Originally Posted by AquilaEagle,Aug 22 2005, 07:55 PM
Yeah pull the 3rd fuse down on the right (blank, fuse, fuse) it is a 7,5. under the steering column
