ECU removal tool
Old 02-18-2013, 12:33 PM
WinFreak's Avatar
Default ECU removal tool
Are there still any around or have they stayed missing?
Old 02-18-2013, 01:47 PM
richmc's Avatar
Mini mole grips.
Old 02-18-2013, 05:02 PM
Ultra_Nexus's Avatar
ECU removal tool
So the ECU bolts are triangular. Damn. Hang on, a triangle has three points (equally spaced in this case). Oooh, three is half of six! what has six points?
Yep, a female torx
http://www.halfords.com/webapp/wcs/s...egoryId_165469
I wasn't going to tell anyone about this, but I feel in a nice mood
Old 02-18-2013, 09:27 PM
WinFreak's Avatar
Thanks for being in a good mood then, I feel honoured.
I already read and thought about what other sockets might fit but I haven't got any imperial sized ones and to go and buy a bunch of them hoping they fit wasn't my first plan
So is that one the right size as well then or did you just pick one?
Old 02-18-2013, 09:53 PM
MB
Member
MB's Avatar
Ron, have you seen the bolt? they aren't completely triangular, the edges are very much rounded off from memory so I doubt that will work and you may end up further rounding off. Torx is better than a normal socket though. Using a stud extractor or the proper tool is the best bet.
Mole grips aren't easy as space is very tight.
Old 02-18-2013, 11:03 PM
blue monster's Avatar
Ron removed my oem ecu within a few minutes using this method. I was stood there watching in disbelief as to how easy it came out
Sent using Tapatalk
Old 02-18-2013, 11:10 PM
WinFreak's Avatar
Do you still have to hammer it on or does it just fit?
Old 02-19-2013, 01:02 AM
My AEM ECU just fits in the slot - no hammer required
Old 02-19-2013, 01:14 AM
WinFreak's Avatar
Erm, I meant the torx socket
Old 02-19-2013, 01:32 AM
mikey k's Avatar
One of the bolts has 3 sides protected by the Honda ECU so it ca nbe a pain getting any tool on it
Once it's off putting an AEM in is a doodle.
Budgie has one of the tools
Quick Reply: ECU removal tool
