ECU Problems
ECU Problems
Hi Guys I may have a problem with the ECU in my MY05. was thinking of getting a replacement from a well know auction site. Im not that technically minded so I was wondering, is it just a case of buying one secondhand and just swapping them over or is there anything else I need to know
thanks in advance for your help
Paul
Paul
UK Moderator
Paul
Paul
You will have to get your key paired with the new ECU.
Chris.
Member
I've got an 05 ECU in the garage with the original VIN number (which you will need to get Honda to code it) if you need one for a similar price. Not available for 4 weeks though
Cheers Guys,
the problem I have is the Rad fan has stopped working, took it into the garage yesterday and the said that it was fine as the fan comes on when the aircon is running but when the engine is up to temp the ecu is not telling the fan to come on. hope this makes sense. I trust the guy 110% with what he is telling me
MB I may take you up on the offer just need to check with my local stealer the price for a re-code
cheers again guys
cheers again guys
You need a new fan switch, it lives in the N/S bottom corner of the radiator - very easy to change and about £12.
You also need a new mechanic - terrible advice.
Sent from my GT-I9300 using Tapatalk 2
He changed the switch first hoping for a nice easy fix, unfortunately that was not the case.
