door window rubber strip unseen, stops rain etc
How to explain...with the window down you can easily pull back the black soft rubber liner on the outer side allowing you to see down in between, just a little lower you notice a another strip liner which is in constant contact with the window all along its edge thus preventing rain/debris from getting into the cavity....I've just noticed when putting the window down its actually pulling the top liner down with it (it kinks half way along, clearly not happy doing so) anyone else noticed this? it may be happening without you even noticing it, I thought something was up when after a dry spell my drivers window would raise but with wet streaks on it..
turbosix
11-20-2011 12:46 PM
