Door handle problem
Door handle problem
Hi, I've had this for a few week I cant remember but may have caused it due to greasing up the hinges/locks etc.
The passenger side door does not open correctly, sometimes when lifting the exterior door handle it wont open at all, the inside handle is not sitting flush either its an inch or two away from the door.
Seems as if it stretched or something?
Any pointers?
I think i might have to take the door card off?
Cheers
Any pointers?
Cheers
I had this problem in my smart car couldn't open the door the outside panel had to be destroyed in order to open the door my advice is act fast before the door doesn't open completely
Unscrew the screw behind the flappy door handle. Prise out the two plastic clips on the grippy door handle, and unscrew the two screws located behind them.
Pull the bottom of the door-card away from the door. You'll hear "popping" noises as the clips come out. Lift the door-card upwards a little and it should come away with very little effort. Then get in behind it and unplug the electrics.
Sorry, I missed a bit. After you've unscrewed the flappy door handle screw, the plastic "housing" that the handle sits in needs to be removed. Just pull the handle to the open position and it'll slide off.
Cheers fella's i did it about 3 years ago when i replaced the speakers, but couldnt remember!.
Do you think there is anything to look for when i have the door card off? or iyou reckon its self explantory?
cheers
cheers
From memory reckon it's probably pretty self-explanatory. The mechanism is all there to see plain as day once the card is off, as far as I remember.
I've only been in there to change speakers, so didn't really pay a great deal of attention to anything else.
Same here, i can just remember taking out the basket etc and lots of see through plastic in there too
cheshire_carper
07-07-2004 11:46 AM
