Doing my bushes :/
Ok after much swearing and with the help of 2 mates I managed to push the metal inner sleeve in, and its currently kept under clamp until I've got new bolts to whip it straight back onto the car. They are a hell of a tight fit!
I have a problem though, I noticed last night that in my rush to take off the arms I seem to have bent the rear lower arm rear collar slightly - can anyone suggest the best way to straighten it back out? Its bent inwards so can't get a hammer to it that way :/
I'm adamant that you should not have such difficulty fitting the poly bush into the arm...something must be wrong. I'll refer you back to my previous question...is the metal shiny inside the arm? Have you checked that the kit supplied is for your MY?
As for the other collar you mention, a photo of what you are describing would paint a thousand words
When I referred to collars/sleeves in my poly bushing thread, they were always something that I removed before fitting the bushes...others did the same. This thread may help:
https://www.s2ki.com/s2000/topic/484...#entry11526207
The metal is shiny inside the arm, but after I cleaned out the rubber...so does that mean there is an outer metal sleeve that I need to remove?
Oh my god, I don't often say this, but 'doh!'
I just thought it was weird that there were effectively 3 metal parts of that bush that needed to be removed - the inner sleeve, a collar and this outer sleeve! So no guesses what i'll be doing tonight!
