DMS 450BHP Supercharge built for Greg
#143
Thats a bugger
Strange its almost like that's the point where the stock ECU has a harsh cut to disable vtec, exactly at 7k rpm.
False knock?
I'm sure you've done it but have you updated the firmware?
False knock?
#144
Yeah one after another, no Vin, faulty map sensor and now ECU problem, hopefully Hondata can give me an answer ASAP so we can get the map finish!
#145
We have disable the knock sensor and put all retard to 0 on all knock related map. Even tho the ecu should retard the timing, not like adding 15 degrees to it.
#147
What the feuck is going on. I'm reading about superchargers and the next thing I know a pic of a scrawny bird appears.
Does she drive a supercharged S?
#149
I need some advise off you Dixon,My fullblown return fuel system does away with the "anti purge solonoid" Iv' asked them if the ecu will show a fault....They told me it can be switched off using the flashpro.Are you aware of this problem and can I disable it using the Flashpro?
Lee FFS
