DMS 450BHP Supercharge built for Greg
#131
Got the new 4 bar map sensor from Hondata now and also we have took the HKS system out and installed the Pro76R on the car as well.
Going on to the dyno later on today, will see if we can get it over 450bhp
#134
Member
#136
#140
Ok got a problem today, so far we only got 410bhp at 8000rpm which is just not too bad but the problem we got is from the ecu.
After 7000rpm the ecu doesn't react to the ignition timing table, seems like the ecu have it's own mind to run the timing. We pulled the timing all the way back even to minus and it is still pulling 15 degrees of timing at 7500rpm.
Everythig before 7000rpm is fine, all air fuel and timing run perfect. So we suspect it might be a ecu hardware problem. We have sent the datalog to hondata now and see what they gonna suggest us to do.
We have mapped with the flash pro so many times and it's the first time we come across with this issue.
Will keep you guys posted with the result.
