DIY Alignment
DIY Alignment
It took 3 hours but following the process detailed by Rob Robinette myself and a mate did a full alignment on my S2k this evening.
I used the same digital laser level as used by Rob and got all settings spot on.
Prior to replacing the seized adjusters, I had noticed that the front wheel alignment was wrong as the front tyres had scrubbed off the insides and the car was very difficult to push, especially forwards,
Having replaced all the seized bushes and adjusters and done the alignment, the car handles a dream and I can now push it, the reduction in rolling resistance is significant, so hopefully will greatly improve the poor fuel economy
Just need the new tyres fitted now, then check the settings again.
Done mine stringing method after doing rear poly bush also using a wixey digital angle gauge
https://robrobinette.com/S2000Alignment.htm
There's a good guide to measuring castor here
http://www.smartracingproducts.com/s...nal_update.pdf
And the rest is here
My string was free,
wixey gauge was £30 done on my own
Setting my front caster when i need too will prove interesting though
I only paid £54 for the digital laser level so still much cheaper than paying for a full geo. I like money saving tips.
Caster and camber were not too difficult,
I made the blocks like the ones in this thread, which made it easy to get to the adjusters
https://www.s2ki.com/s2000/topic/111...nt-calculator/
Thanks for the link,
pushed mine back and forwards on planks of wood for little extra height after adjustments made and fumbled around under car for many hours wearing my knees out.
