Displays for AEM EMS
#61
Will take some and post if you're interested. Will get round to it eventually (I keep forgetting)!
#64
Originally Posted by s2konroids
Way this was recorder software? Not command type prompt or batch file?Cheers
#65
To connect to aem tuner automatically, run it and select guages tab automatically as I was aware you have to do this manually, your saying you have automated this process?
And did you use a batch file etc or software that recorded what you did and it just runs that on start up?
Cheers
Cheers
#66
Cheers
Cheers
I set up AEM Tuner to run at windows logon (depends which windows version you have, but it can be a bit fiddly as some apps don't work in the simple way on some versions, which is to put it in the startup folder. Plenty of info to be found via Google though).
AEM Tuner has a setting in its preferences to load a default map and workspace, and a default tab (although I just moved the gauges tab to the front of the list instead). And you can set it to automatically connect to the EMS.
The only snag is that you need ignition on for it to start connecting, then off and on again to finish connecting. No great shakes though.
#67
Is this off and on stuff so the tablet boots, then detects the connection on the second ecu turnover?
Pics would be good if you can as I'm still on the fence with this
#68
