Displays for AEM EMS
Old 11-04-2015, 03:47 AM
  #41
chrispayze's Avatar
Originally Posted by mikefifth
Can you keep this thread alive with how you develop this please. Very interested.
Will do! Cheap windows tablet ordered, plus Bluetooth keyboard with track pad, as screen real estate will be limited! And a OTG USB adapter so I can plug it into the EMS. I've also been examining the pinout for the EMS. I reckon I'll add a proper oil pressure sensor in place of the OEM low pressure switch, take the output to the EMS, then connect the dashboard oil light to a spare output on the EMS. Then I can set a minimum pressure, under which the light will come on. Needless to say, that will be higher than the OEM setting! I could use the same light for oil temperature too. I wonder if the EMS will let me make it flash or be steady, depending on the cause...hmmm.. For AFR, Boost etc, I can set the EMS to switch the CEL on.Now I just need to teach myself the AEM Tuner software...
Old 11-04-2015, 03:48 AM
  #42
chrispayze's Avatar
Urg, no carriage returns when typing in the android app!
Old 11-04-2015, 06:23 AM
  #43
s2konroids's Avatar
I use the cel light as a shift indicator
Old 11-04-2015, 08:49 AM
  #44
chrispayze's Avatar
I thought I might use the key light for that!
Old 11-04-2015, 10:34 AM
  #45
mikefifth's Avatar
You serious?
Old 11-04-2015, 11:21 AM
  #46
chrispayze's Avatar
You serious?
I'd guess so. Romain enlightened me as to the potential use of a dash light as a shift light. Not sure it would give you much better an indication than the Rev counter though, even further from your centre of vision.
Old 11-04-2015, 11:45 AM
  #47
CynicG's Avatar
Don't you just shift a few rpm before the redline?!
I like this thread. Good food for thought.
Old 11-04-2015, 11:54 AM
  #48
MB
Member
MB's Avatar
Never felt the need for a shift light in the S
Old 11-04-2015, 01:26 PM
  #49
s2konroids's Avatar
I dont really use it, its just a fad i did it because i could, i rev to 9200rpm.
Old 11-04-2015, 01:47 PM
  #50
mikefifth's Avatar
Not to go too far off topic but how did you manage to up the RPM limit, stock internals?
Mark, do you not think the racecar could use some more flashing lights?
Quick Reply: Displays for AEM EMS
