Diff And Gear Box Oil Change
Have you noticed any differences?
Mine goes in for her first service Friday and I'm having all fluids changed.
Honda MTF in the box and Silkolene 90 in the diff.
Must be service month,as i changed my oil in diff,redline oilhigh shock oil.
also changed my engine oil,aftermarket oil filter (Oh dear!!,bad move!!) (Its another story!)Also took drive shafts out and regressed them!!
I didn't think the shifting could be improved but it certainly has - especially when the car is cold. The diff works better too I think. When I used to push the car into corners, I would get a slight slide and then I'd feel the wheels lock up and the car would tighten the turn. Now with the new oil, I don't get the initial slide but a solid lock up from the rear wheels instead - I love it this way.
S2000silveVTEC - I would have a read ogf Xvipers thread on Redline shockproof oil - some very interesting findings.
Xby - you should have brought back a load of them!
Thanks for all yoru help and advice
Prior to owning an S2000 I had zero tools, so far I've bought:
1 x 10mm spanner - Snapon
1 x 1/2 inch wratchet - Snapon
1 x 12mm socket - Snapon
1 x allan key socket - Snapon
1 x rubber mallet -
1 x rubber mallet -
Originally Posted by Amuse Boy,Jul 17 2004, 10:35 PM
All I need now is a decent torque wrench - I think my neighbour gets a bit peeved when I keep borrowing his - `tis a good thing that he's a mechanic!
Anyone know what those are for?
Originally Posted by Neil.H,Jul 18 2004, 12:45 AM
I got a torque wrench from Helfords, seems to be good quality, 40-200nm I think. Comes in a pastic case that fits nicely into those 2 straps in the boot just under the latch and above the tool tray.
Originally Posted by Amuse Boy,Jul 18 2004, 01:02 AM
The straps are for holding a flat tyre - if you remove the tool tray, you can fit a tyre standing up and the straps are there to secure it.
