Diagnosis: Gearbox issue
Hi all,
4 weeks ago I heard a different noise to the usual S2000 tuneful notes. At the service 3 weeks ago I suggested it might be a wheel bearing and they investigated, couldn't find anything and said wait for it to get worse.... it got worse.... rapidly! After a very short trip it smells like something is getting warm.
Today it has gone in for what I thought was a wheel bearing or diff issue as the noise varies due to rolling speed, not revs related. Garage has said wheel bearings are fine, diff is fine, problem lies with gearbox and they can see some small metal filings. I have had no problem changing gears although have driven on the careful side since I thought a wheel bearing was about to go.... could a bearing have seized in the gearbox?
What I'd like to know is if anyone else has had an issue with the gearbox like this. I know it's very hard to describe a noise.
Car has done 103,000 miles and has the clutch buzz issue so if I do need work on the gearbox then I will get the clutch changed as well. Could the clutch buzz issue have caused a problem with the gearbox??? I have done 55,000 miles in it so far and had no major faults.
Thanks for any comments.
Common on all older RWD boxes is the gearbox output shaft bearing.
Often a little more noisy when coasting down in gear - a deep whining growl that is often on/off as you apply/reapply power.
Sound like it?
Sound like it?
mine has the output noise , and clutch buzz - fix - turn up the volume of the radio
though does not ' smell ' like its getting warm - have you got out and checked to see if the wheels are warm ?you may have a binding caliper ? also pop the bonnet - anything very warm ?
Volume of noise increases as speed increases, nope no on/off as apply/repply power.
Have been happy with clutch buzz for 4 years and no need to correct it now although will be cheaper to change clutch at same time.
Definitely hot smell from rear of car, not tyres, not brakes. First check was if the wheels are warm, brakes fine. Same smell inside car too.... (not me!)
Concerned about the metal filings though.... cost me nothing except servicing and brakes/tyres so not totally unhappy. Garage have suggested a gearbox specialist nearby.
It's probably not worth fixing the gearbox. Mine from a low mileage MY04 cost £400 from a breaker, and you'll have to pay the labour for removing and refitting either way.
I'd have thought once on ramps it would be obvious where the smell and heat was coming from.
The hot smell is burning hypoid gear oil sir
Maybe a bearing picked up and spinning in the housing.
Demob's got the best idea, sack it off and get one from a breaker.
Last box I had refurbed by the BIL as we were too busy, cost £450 at mates rates and that was a crappy old Suzuki!
soHybridized
09-14-2011 04:46 PM
