Deeper problems than I thought...
My dipstick blew out of the engine when running on the dyno (at 9k rpm)
I have checked the breather system and catch can setup and is all fine, the compression test came back as it should, the PCV valve is in full working order.
My car is supercharged and running 11psi.
I think it might be pressure entering the crank from elsewhere, maybe through the bearings?!
Now I am really worried its rebuild time......
Any advice / help / knowledge on this would be massively appreciated as am really worried about my car
North London, N3 2QG. Is it too far for you?
Hahah! Thanks I don't know whether to take that as a compliment or not LOL
Originally Posted by WinFreak
Joeh is the one to see here, this man knows everything about dipsticks!
Here is a thread of yours I found earlier where you are on about the exact same thing...
https://www.s2ki.com/s2000/topic/102...lready-needed/
Own post to me.
And yes I am posting about the issue being worse than I thought as now have done a comp test and PCV and breathing.................
