De-Cat
Old 11-30-2007, 01:47 PM
Kiwi-S2000's Avatar
Rrrr the smell of petrol
Old 11-30-2007, 02:01 PM
Boab01's Avatar
Oh man, put a decat on
Just get a friendly tester who will put yours on for the emissions test and then swap it back when they're done. My dealer will do this for me (when I get a decat for the FD2)
Old 11-30-2007, 02:06 PM
MB
Member
MB's Avatar
I just leave mine in the boot and give them a wink
Old 12-01-2007, 02:02 AM
s2konroids's Avatar
Heres a question how lean do you run with a decat?
cheers
Old 12-01-2007, 03:02 AM
MB
Member
MB's Avatar
No more lean that would cause a problem.
This isn't a turbo car.
And even they can generally be decatted with no issue.
Old 12-01-2007, 04:19 AM
apkent's Avatar
As said, it isn't illegal to take the test with a decat, so long as you pass the emmisions. In any case you either need to lean it out to try and pass, or put the cat back on. Of course you won't know if it'll pass until you try, so probably best to get it fitted, then taken off again afterwards.
Old 12-01-2007, 07:28 AM
JimUK's Avatar
or just make sure you know the guy who is mot'ing it as already said!
Old 12-01-2007, 12:06 PM
Trackaction-Online's Avatar
Leaving aside the difficulty in weakening a engine running closed loop control, if you do run it weak it will probably pass on CO but fail on lambda due to the high O2 readings
Old 12-03-2007, 12:24 AM
Bibbs's Avatar
Mine with no cat, an SC and 750cc injectors passed.
It had the same output as my mates Aygo. Strange
Old 12-03-2007, 12:34 AM
S2000_FUN's Avatar
If you don't have already the decat (test pipe) and you are thinking to buy, then i will propose you the Berk test pipe. It is still a cat pipe (100 cells), you will pass MOT and it has almost the same performast as the test pipe.
rossco
03-11-2016 12:53 PM
cat5cable
10-09-2013 01:24 PM
sabry
06-07-2006 12:44 PM
Jeff
07-18-2001 01:17 PM
Quick Reply: De-Cat
