Dash Mounting Bracket for RHD?
Old 07-26-2006, 12:48 PM
  #21
j8mie's Avatar
Originally Posted by modifry,Jul 26 2006, 09:23 PM
Remove plastic housing around the steering column
Loosen steering column bolts and drop column down for clearance
Remove plastic plugs under speedometer cowl & remove screws (I thnk those are the only screws)
Pry, carefully, the bezel away from the dash.
Insert long skinny fingers behind bezel to unplug a million wires
Pull bezel away from dash
The radio and heater controls come off with the bezel.
Cheers dude I'll give that a try
Old 07-26-2006, 01:55 PM
  #22
mikey k's Avatar
As the dash is a mirror image why not make the bracket symetrical along the horizontal centre line
That way it would fit LHD and RHD just by rotating it 180 in the vertical
You would need to be able to fix from either side of the mount though!
Old 07-26-2006, 02:22 PM
  #23
andyds2k's Avatar
Just another of the wall idea, how about copper paint on the braket instead of flat ribbon cable. Then laquer other to given insulation. The only thing is I would be concerned about the robustness of it all, specially where the bracket mount goes between the bezel and the dash.
If a think of some more wierd zany ideas I will let you know
Old 07-26-2006, 03:25 PM
  #24
User 11317's Avatar
[QUOTE=modifry,Jul 26 2006, 08:18 PM]OK, what the heck is going on?
Old 07-27-2006, 12:49 AM
  #25
Shipley's Avatar
Originally Posted by AquilaEagle,Jul 26 2006, 08:57 AM
I'd like my phone there, I hate those things that cover the vents.
Ian
Why not buy a
Old 08-02-2006, 10:31 AM
  #26
modifry's Avatar
[QUOTE=Shipley,Jul 27 2006, 03:49 AM] Ian
Why not buy a
ungucpho
Socal Swap Meet
11-12-2011 10:16 AM
iDashX
09-11-2011 05:18 PM
s2konroids
07-31-2011 09:38 PM
hariku821
12-23-2009 12:34 PM
Darien1629
06-13-2004 11:23 AM
Quick Reply: Dash Mounting Bracket for RHD?
