Dark smoke
My S seems to pumping out black smoke when i first start the car - its a MY2000 with 23,000 miles on the clock.
Something to worry about?
Cheers,
Cheers,
Cheers,
Cheers,
am i making myself clear?
1 Post
Originally Posted by phase_k,May 17 2005, 11:08 AM
Wouldn't oil be grey smoke??
Does it just burn oil when you start up or even after its warmed up?
1 Post
Originally Posted by andrewcfm,May 17 2005, 11:24 AM
It happens after i've been driving for a couple of minutes, and then it stops.
Er, am getting a bit worried now!
It doesn't sound like a piston ring because if that was buggered you would expect to see a smokescreen being laid down at all times.
It might just be a blocked breather pipe.
Suggest you get a competent mechanic to look at it rather than just worry and speculate what it might be.
if it runs like shit could be the MAP sensor needing a tap and the \ECU resetting...
mine ran like a totaled parcel one day i did that and it has given 110% ever since without further hiccups.
but also check ur oil and get a warrenty over the phone incase its not that !!!
raz
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
raz
raz
raz
