Damage due to oil?
Damage due to oil?
Hi guys.
I have had a look through searching and couldn't find anything relevant initially but please excuse me if this has been covered.
My car was serviced by a well respected company last week and during my weekly check over the car, checking fluids etc i noticed the oil level was WAY above the high mark, like 8mm higher. The car was on pertectly level ground and I did the usual wiping the stick clean and re dipped it to produce this reading. I have commuted to work all this week and still it's this high!? Surely this isn't good and will damage the cat? Also, the clutch fluid is black still despite me asking them to change it.
Clearly I need to go back to them to see if they actually changed the clutch fluid too. Are the clutch and gearbox fluid one and the same?
Thanks,
Dan
Thanks,
Dan
Hi guys.
Thanks,
Dan
Thanks,
Dan
Your second question is a highly confused; the ethylene glycol fluid in the clutch reservoir actuates the release mechanism in a similar way to the brake actuation in the reservoir adjacent to it; hydraulic pressure. If it's still black, simply threaten to make the service manager's eye a matching colour.
Gearbox oil is a lubricating mineral (or synthetic long-chain polymer blend) oil with additives which lubricates and cools the mechanical friction of the reduction gears in the transmission box.
Definitely not. Use Honda MTF or an equivalent for the gearbox.
Dan - don't bother fannying about with getting underneath the car and using the drain plug. It'll make a proper mess. Go to your bathroom sink, switch on the tap then plug it with your finger... notice how wet you get? As for a 'clean' jug, I wouldn't put any oil / fluid / lubricant of any kind back in once drained from anywhere. Use some of your top-up (hopefully you've got some) instead. The filter method is clean and it means you can do it from under the bonnet.
Thanks for the comments guys, just wanted to know about any possible damage etc. I'll be contacting them regarding this ans work I have asked for has not been undertaken and overfilling the engine oil can be devastating to some engines, do that on my 220bhp golf turbo and it would destroy the cat amongst other things!
A cat can be replaced with ease and without too much of a dent to your wallet. An engine, on the other hand, due to low or a lack of oil would be much more expensive and time consuming. You've gone over by a few hundred mils, so I wouldn't worry. If it'd been overfilled by a litre or more, I'd be worrying. Chill. All is good.
Hand tight on these engines is not tight enough.
